Brief Description: Cut and drilled aileron control rods
Today I cut to length and drilled the aileron control rods that extend from the wing bellcrank to the aileron, see image 1. I also did the leak test of the left wing tank using the manometer method, pressurizing the tank via the vent tube with the fuel pick up tube capped off, see image 2.
